240Z Engine Mod Questions...
Guest andy.tech
Start by reading the FAQs and stickies as MatMan suggests. The L6 FAQ is not the best, so then you should start searching in the L6 forum for info on building up an engine. You'll find lots of info on the heads, cam timing, etc. There is no one answer for your question as to how much power you're going to get. Here are a couple of the many good threads you'll find by searching.
http://forums.hybridz.org/showthread.php?t=89812
http://forums.hybridz.org/showthread.php?t=104420
http://forums.hybridz.org/showthread.php?t=111523
1. The only substitute for cubic inches is cubic dollars.
2. Adding Turbo's is like adding cubic inches.
3. Carburetors are just semi metered fuel leaks.
4. Decide on a realistic budget. Tell us how much you want to spend, then we can tell you what you can get out of it.
Guest andy.tech
Well I don't wanna go turbo since I already have a turbo car and I'm really after that nice 240Z Side Draft sound. But as far as $$ goes I dunno maybe the question I'm really asking is what "Can" be done with these motors or how adaptable are they. I don't know much about these motors but I do know that they have an awesome sound!!!
