Z31t companion flanges into 240Z?
Z24O
Just did a search,but nothing definitive,I have some 4 bolt Z31 turbo halfshafts that I believe I can use in the R200 CV conversion(need to reverse the bearing carrier)
Question is can I use the Z31 companion flanges or is there an issue with bearing or length compatability with the 240Z hub/stub axle??
The splines (25) seem to match on the sample I have so that's one obstacle out the way
I know Ross sells the adapters if I get stuck but if I can use OEM parts then I will
I have a 280zxt setup for my other 240Z (compliments of Terry) but have a spare pair of Z31t shafts that I may as well use if I can.
Thanks guys.
Here's what I have measured:
240Z and 280ZX stub axle:
25 splines
spline outside diameter = 25.8mm
280Z stub axle:
27 splines
spline outside diameter = 27.8mm
Z31 stub axle:
26 splines
spline outside diameter = 27.5mm
So, in my opinion, the answer to your question is no.
