Kash Posted June 10, 2007 Share Posted June 10, 2007 Has anyone installed one of these on their zxt? Do I hook up the LMA-2 input rpm signal to pin number 5 igniter signal from the ECU or should I hook it up to the negative side of the coil? The instruction manual that came with the unit does not help much. Thanks. Quote Link to comment Share on other sites More sharing options...
ARZ_ Posted June 11, 2007 Share Posted June 11, 2007 Im anxiously watching this thread for the answer. I too have an LM-1 with the RPM harness and will be down loading and logging data too to see where I should be adding or removing fuel with my fuel controller. Since Im running the 7MGTE ECU Im not sure the answer will help but I can hope. Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted June 11, 2007 Share Posted June 11, 2007 Without looking at the manual I would think that the negative coil would work. Try it out and see if you get a rpm signal. Mine is interfaced with SDS so it's different. Quote Link to comment Share on other sites More sharing options...
