toughford86 Posted June 22, 2007 Share Posted June 22, 2007 i have a L20b motor out of bluebird it has points dizzy i have set the timing right at 6 degrees btdc and it still wont start keepos backfiring and catching on fire in the carby Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted June 22, 2007 Share Posted June 22, 2007 Your Distributor is 180° out of the timing mark. Move your spark plug wire 180° around the cap and it should start. Quote Link to comment Share on other sites More sharing options...
rags Posted June 22, 2007 Share Posted June 22, 2007 What he ^ said Quote Link to comment Share on other sites More sharing options...
toughford86 Posted June 22, 2007 Author Share Posted June 22, 2007 which direction should the rotor botton pointing front of engine or back of engine Quote Link to comment Share on other sites More sharing options...
toughford86 Posted June 22, 2007 Author Share Posted June 22, 2007 do i have to change the cam timing it was set for electronic dizzy Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted June 22, 2007 Share Posted June 22, 2007 Why do you post three threads with the same thing in three different places? Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted June 22, 2007 Share Posted June 22, 2007 It sounds like you are new to working on a motor. The engine turns Twice to every turn of the dizzy. Take off of the dizzy cap and look were the rotor is pointed when the timing marks are lined up. Put #1 spark plug there and use your firing order to set the rest. Try to start the engine. If it doesn't start and is firing back through the carb rotate the wires 180° around the dizzy cap. Keep it safe Quote Link to comment Share on other sites More sharing options...
toughford86 Posted June 25, 2007 Author Share Posted June 25, 2007 new to woking on nissan last time i tried to work on one of these the motor catch a light want to make sure every thing is right Quote Link to comment Share on other sites More sharing options...
