wickiewicked240z Posted July 3, 2007 Share Posted July 3, 2007 I'm using Z32 seats I had to fabricate new mounts for them so i can get the stock height as the original 240z seats wich i think is about 35 inches from the floor to the top of the seat. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted July 7, 2007 Share Posted July 7, 2007 Just a heads-up to everyone about seats.... I cannot recommend the type of seat that uses a mechanical plate to provide lumbar support. I had a Conquest and was rear-ended at the age of 30 - 23 years ago. I still have problems with my lower back - right where that plate was. The entire rear of the car was crunched into the rear wheels. If you want/need lumbar support - get seats with inflatable bladders! I may decide to try and modify the stock seats with some welding and utilizing air bladders and closed cell foam and some garbage bags in order to get more support - at least I'll know I have enough headroom. (I'm ~5'11 1/2" and inseam is 30") Quote Link to comment Share on other sites More sharing options...
Careless Posted July 11, 2007 Share Posted July 11, 2007 Here is the problem area you will find with the later S30 chassis that came equipted with catalytic converters. They have a "hump" in the transmission tunnel to allow for more clearance in this area. This just gets in the way when mounting most modern seats. Jusitn my 76 dont have that =/ Quote Link to comment Share on other sites More sharing options...
Wout van Aken Posted November 23, 2008 Share Posted November 23, 2008 Hi, I had the same problem. I chanched the "bump" in the tunnel and mounted recaro seats in it. See my pic. Quote Link to comment Share on other sites More sharing options...
