Chemicalblue Posted July 1, 2007 Share Posted July 1, 2007 Im hoping that this is the right place for this post. I have 79zx and Im trying to find the correct settings for the original tacho in the dash. For whatever reason Im getting no needle movement on all the different settings I have applied. Here are the choices Output state: Inverted or Normal ___ Tacho Duty 0-100 ___ Tacho pulses per rev. ___ These are the settings for the Haltech output to drive the Tacho, I have it hooked up to the blue wire that goes directly to the tacho. Any help or advise would be greatly appriciated. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted July 1, 2007 Administrators Share Posted July 1, 2007 I have 79zx and Im trying to find the correct settings for the original tacho in the dash. For whatever reason Im getting no needle movement on all the different settings I have applied. Tommy, I have had trouble with zx tachs and aftermarket EMS's. What I normally use is the MSD tach adapter 8920. Assuming Haltech can output a 12v square wave (typical) it should work for you. http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&Ntt=msd+8920&x=0&y=0&N=+115&searchinresults=false Quote Link to comment Share on other sites More sharing options...
Chemicalblue Posted August 9, 2007 Author Share Posted August 9, 2007 Ron, Once again you have offered great info, the MSD 8920 worked perfectly. Thanks. You have been a great help. I plan on posting all my settings and info once everything is worked out. Its been a great learning experience, a little frustrating and allot of fun. Tnx Again Tommy Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted August 9, 2007 Administrators Share Posted August 9, 2007 My pleasure. Thanks for letting us know it worked! Quote Link to comment Share on other sites More sharing options...
