jerryb Posted July 14, 2007 Share Posted July 14, 2007 I just installed a Stewart Warner Tach into my dash. After about an hour worth of work it fit perfectly even using the stock plastic bezel and lens...just like stock..well, pretty darn close. I may be a bit biased but its this most "original" aftermarket install I have seen from an off the shelf unit. The only thing I need to do is paint the needle white. I will post a pic or two shortly. The tach is working but reading 1/3 the actual RPM. It has pins to adjust the reading and per the SW instructions I need to obtain a 9PPR (9 pulses per revolution) Currently it is set on 3 PPR but I cant figure out how to set the pins for 3x the reading...... Anyone have luck with this .....or should I go with that Gizmo off summit racing Quote Link to comment Share on other sites More sharing options...
jerryb Posted July 14, 2007 Author Share Posted July 14, 2007 Pics Quote Link to comment Share on other sites More sharing options...
Stealth-Z Posted July 14, 2007 Share Posted July 14, 2007 Looks good. I like a simular factory install look. Quote Link to comment Share on other sites More sharing options...
MrFancypants Posted July 14, 2007 Share Posted July 14, 2007 I find the SW stuff to be better quality than AutoMeter, and they look great in the Z dash! You could also try something other than their Max Performance line to get a white needle... - Greg - Quote Link to comment Share on other sites More sharing options...
Careless Posted July 15, 2007 Share Posted July 15, 2007 VERY slick. good choice =) Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted July 16, 2007 Share Posted July 16, 2007 what diameter gauge is that? nice install! Quote Link to comment Share on other sites More sharing options...
