What would you pay for a ring and pinion?
rudypoochris
Just tring to guage interest. How much would you pay or consider reasonable for a used R200 ring and pinion in a 4.375 ratio, a 3.36, or a 3.7 ratio? What is reasonable for a brand new copy of one of those ratios if a copy existed? Talking about just the gears. Thanks.
Nissan Comp sells R&P sets, although who knows how many they have left. Currently they show 4.11 and 3.70 gears in stock at $650 on Courtesy Nissan's site.
A new ring and pinion for a Chevy is ~$225, so I'd figure an aftermarket set should be somewhere in the middle, maybe $350 to $400.
Personally I wouldn't try to set up a used set of gears in a new housing. The R diffs are so damn noisy as it is, and if you don't get them set just right they're going to howl. I'd try to find a diff with the correct gear ratio. Old Skylines came with the 4.375s, 3.70's are common in the Z31s. The 3.36's are tough to find and only came in the 74 and 79 2+2s as I recall.
