tach troubles
I have a 76 all srock and the tach likes to fall to zero some times and then it will bounce between zero and the correct rpm. i have replaced the transistorized ignition unit under the dash on the passenger side with one from a 77 and that seems to work alot better than the dual pu unit i had in it plus i did cahange the dual dizzy to single and hooked it ap accordingly( found out if i hooked up the white wire the car wont shut off!) after i did that the problem went away, as well as the performance returned! performance is still good but now the tach is bouncing again, now that i have bored you with the history here's the question i need answered... where is the resistor located on the car for the tach????:fmad:
it is the only thing i havent replaced because i cannot find it:sad:? help please?? I searched and could not find any info on the location nor does my books show the location
