confirmation for clutch swap
madkaw
I have a p-30 that i have installed a bwt-5. I had my flywheel balanced with the engine so I need to use the 225mm flywheel. Ssssoooooo, if I buy a standard coupe clutch kit, as long as the collar matches the pressure plate( i.e. 280z coupe ) it all should work-right?? Any recommendations on a good clutch, not too heavy, that will work-cheap helps!!!
