john kosmatka Posted September 22, 2002 Share Posted September 22, 2002 Are strut bars and sway bars a good modification to z cars to improve handling. Quote Link to comment Share on other sites More sharing options...
evildky Posted September 22, 2002 Share Posted September 22, 2002 get the fattest front sway bar you can find, and yes you will notice the difference especially if you autocross,takes out a ton of body roll, I have no experience on the strut tower bars Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 22, 2002 Share Posted September 22, 2002 Strut bars stabilize movement of the strut towers under extreme manuevers. Larger sway bars aid better cornering with stiffer springs and struts. It would only be practical to add larger sway bars if the springs and strut cartridges were upgraded to stronger units. Quote Link to comment Share on other sites More sharing options...
260DET Posted September 23, 2002 Share Posted September 23, 2002 A large, strongly mounted FRONT sway bar helps a lot. IMHO the stock Z front sway bar mounts are not strong enough. Unless for some reason you want the rear to lose grip when cornering hard fairly readily, I would not use a rear sway bar. Concentrate on improving the front suspension first anyway, good shocks and some negative camber at least. Quote Link to comment Share on other sites More sharing options...
