strut spacer tubes
I recently had a friend purchase some of this equipment, and base upon the very minimal information you've provided, I'm going to assume that it is the overall "kit" you're talking about, and not specifically the lowering springs. I BELIEVE what you're talking about is the upper assembly (camber plates) that allow the user to lower the car without shortening the strut simply from using the additional clearance gained on the upper end of the strut rod when you remove the OEM parts.
