need help deciding gear ratio behind my V8.
HICKL
I broke my R200 again and I have two donors to replace with. One is a 3.55 and one is a 3.7 ratio. I'm trying to decide which would be better for my 1/4 mile times. Keep in mind, I am running a manual 5 speed. Will the added pull of the 3.7 be outweighed by the fact that I will blow thru first gear even quicker? I've never really played with gear ratio's so any input would be appreciated. My power plant is a fairly stout 383 so factor that in as well.
Or, are they so close that I won't even notice any difference.
Thanks for your input.
Jeff
gear spread sheet that comes in handy THANKS TO 1FATGMC
http://purplesagetradingpost.com/sumner/bvillecar/bville-spreadsheet-index.html
THE 3.73 RATIO, PUTS SLIGHTLY MORE USEABLE POWER, DURRING A RUN TO THE PAVEMENT, (ASSUMING YOUR RUNNING THE SUSPENSION AND TIRES TO LAUNCH HARD) KEEP IN MIND youll spend over 90% of the time in the 3500rpm-6500rpm band durring a race, exactly where your 383 is cammed to run
HERES OTHER INFO LINKS
http://www.wallaceracing.com/reargear.htm
http://users.erols.com/srweiss/calcmph.htm
http://users.erols.com/srweiss/calcrpm.htm
http://users.erols.com/srweiss/calcrgr.htm
http://users.erols.com/srweiss/transc.htm#tabtop
http://users.erols.com/srweiss/transc.htm#Auto
