Paul260z Posted October 2, 2007 Share Posted October 2, 2007 I would like to know how to use the stock knock sensor on the l28et motor. I am using the error* board and want to use knock sens. Tried different things but nothing seems to work. any Ideas on how to wire the sensor? Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted October 7, 2007 Share Posted October 7, 2007 id like to know this as well thinking of turning the boost up and would love to know if the stock knock sensor will work with megasquirt Quote Link to comment Share on other sites More sharing options...
datman Posted October 8, 2007 Share Posted October 8, 2007 You need to process the signal from the stock sensor to give a 0v to 5v output depending on knock. Quite a few production cars have a signal processor that can be used to filter the signal from the sensor....Saab turbo's for one. http://www.geocities.com/motorcity/garage/6776/apc.html better link here http://www.mswanson.com/~jgreen/APC/APC.html Quote Link to comment Share on other sites More sharing options...
mobythevan Posted October 8, 2007 Share Posted October 8, 2007 I went ahead and bought the Knocksense module for $60 to allow me to interface with the LS1 knock sensors. You could find out if it will work to interface to the Nissan sensor. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted March 6, 2009 Share Posted March 6, 2009 sorry to bump this old thread but I'm curious as to results http://www.viatrack.ca/ read that site and the posts here and would like to know how well the knocksense works or if it is even needed for MS -Ed Quote Link to comment Share on other sites More sharing options...
mobythevan Posted March 6, 2009 Share Posted March 6, 2009 Wow, time flies. My turbo is bad on this car so I haven't got to tuning and using the knock sense module. I have a feeling it is not going to work well on this 5.3 engine because it has the notorious lifter knock. I think that is going to set off phantom knock. One of these days I will find out. Maybe others have new input on the knock sense module. Quote Link to comment Share on other sites More sharing options...
slown280z Posted March 7, 2009 Share Posted March 7, 2009 A buddy's car has this with their supplied knock sensor and a custom stud to adapt it to the original position. We can't really seem to stop it from going off in high rpm situations, even with low load and a conservative tune, which I doubt is causing engine knock. It has a little POT to tweak sensitivity, and I feel we can't get it insensitive enough. That or the stock position is too noisy and his exhaust too loud. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted March 7, 2009 Share Posted March 7, 2009 interesting. So your having a problem with too much sensitivity. I might have to try this out. I was afraid it would not be sensitive enough and hear the faint knock that I would not be able to hear in car. -Ed Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted March 8, 2009 Share Posted March 8, 2009 I had a conversation w/Boris a few years ago, and we use a Bosch knock sensor that KnockSense supports... Quote Link to comment Share on other sites More sharing options...
slown280z Posted March 8, 2009 Share Posted March 8, 2009 interesting. So your having a problem with too much sensitivity. I might have to try this out. I was afraid it would not be sensitive enough and hear the faint knock that I would not be able to hear in car. -Ed Yea, this is with their supplied Bosch sensor. The car is really loud though, external wastegate turbo, 3in dp/exhaust with a 6in body magnaflow in the trans tunnel where the exhaust ends. Quote Link to comment Share on other sites More sharing options...
