L28ET almost overheating all the time
Omar
so i have a 240Z with an l28et. the motor is pretty much stock just intake and exhaust. it used to go 3/4 of the way to hot on the temp sensor when i was pushing on it alot. one time it got to the H when i was really beating on it on the highway.
since then every time i drove it it get about 5/6 of the way to H but never more. And it bubbles into the overflow after i turn the car off. and now it happens with just normal driving after about 8 minutes. but it will idle forever and not get past half.
i did a leak down test at about 60psi and detecting nothing as far as a bad HG or warped head. there is no burning of coolant and nothing leaking. I also took out the thermostat, just to get rid of that variable. and it didn't help.
any suggestions.........please?
Only timing you need to worry about if you don't mess with anything is cam timing.
Just scratch a place between two circles on the gear, then mark the two links that go to the left and right of that scratch.
I've done it this way twice. Makes for a headgasket job in less then 2.5hrs.
Mario
Go by the piston position. If number 1 is up and the intake and exhaust valves are closed then you're at TDC. I got lucky because my crank mark is still accurate (of course I checked to make sure).I just spin the motor until the cam number 1 and 2 lobes are up the timing mark lines up at 0 on the plate. The only time I had a problem was when I replaced the oil pump and didn't prime it before cranking. No oil pressure puts no pressure on the chain tensioner which allowed the chain to skip. Of course I didn't realize this until I found the eye brows in the pistons from the exhust valves.
...So did I miss something? How come you are jumping straight to 'replace the head gasket' for this problem? That's a pretty major chunk of work if you haven't isolated the problem yet.
If you are going to 'shotgun', start with the easy stuff first.
well if i open the radiator cap and i quickly tap the gas, bubbles come out of the radiator, thats a bhg as far as i know.
how do u prime it first??
