peej410 Posted October 26, 2002 Share Posted October 26, 2002 Hey all i just finished my first floor ever on my Z and i wanted your opinions. if the links dont work, cut and paste the urls. Id like any and all constructive criticism. IE: if i did something wrong dont be afraid to say so... BTW the floors look alot worse then they are because i started stripping the anti rust goop so that i can paint them - pete http://www.geocities.com/peej410/mvc-015s.jpg http://www.geocities.com/peej410/mvc-017s.jpg Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 26, 2002 Share Posted October 26, 2002 PJ...... cannot get in RE-EDIT: Looks good Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted October 26, 2002 Share Posted October 26, 2002 Did you make those floors yourself? Looks decent Pete. !M! Quote Link to comment Share on other sites More sharing options...
RPMS Posted October 26, 2002 Share Posted October 26, 2002 Looks good to me! That's the beauty of welding in floors, as opposed to welding body panels or something like that. When you're done, you'll slap some undercoating on one side, and carpet the other. Nobody will ever see your mistakes! Quote Link to comment Share on other sites More sharing options...
Guest jdllaugh Posted October 27, 2002 Share Posted October 27, 2002 Thanks for posting the pics. They are inspiring. Right now I just have a big hole where my driver's side floor used to be. I know I can do this project, but it's really nice to see someone that's been there, done that!!! Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted October 27, 2002 Share Posted October 27, 2002 I couldn't get in either. crap and I wanted to see how yours turned out. Mike Quote Link to comment Share on other sites More sharing options...
Mudge Posted October 27, 2002 Share Posted October 27, 2002 Left click and DRAG the link to the IE Address bar, that will work with Geocities and Tripod etc. Quote Link to comment Share on other sites More sharing options...
denny411 Posted October 28, 2002 Share Posted October 28, 2002 nice work I`m lucky enough to have solid pans in my Z, but my chevelle is another story I`ve spent all week welding quarters,wheelhouses,floorpans, and frame and body mounts. I hope to set the body down on the frame in the morning, finally. wish me luck Quote Link to comment Share on other sites More sharing options...
peej410 Posted October 29, 2002 Author Share Posted October 29, 2002 Thank you all for the kind words, sorry about the links, geocities doesnt really like being linked to. Yes i did make the floors myself, i also made my own makeshift sheet metal brake using two 4 foot pieces of angle iron and three large c clamps. one welded on each end (the wont stay if they arent welded) and one positoned in the middle. The inherent downfall to the design is that the center clamp limits the distance from the edge of the sheet to the bend. anyways thanks again guys 1 down 1 to go good luck denny with the chevelle post pics if you can when that puppy is done -pete Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 3, 2002 Share Posted November 3, 2002 Nice work! this is in my near future as well. What gauge metal did you use? Twydog (Passenger side had a 10"x2" hole under the rubber insulation...orshould I call that stuff a 30-year old sponge?) Quote Link to comment Share on other sites More sharing options...
Corzette Posted November 4, 2002 Share Posted November 4, 2002 PJ, looks good but how thick are those? Looks like you didnt have much trouble shaping them. Man I used 1MM thick Zinc material and was a royal pain inthe A$$. At least they will never rust again. If you want to see mine up close check out my site for reference...good job!! Corzette Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted November 4, 2002 Share Posted November 4, 2002 pj on the rails did you move them down or did you move the floor up to get the flat floor? Quote Link to comment Share on other sites More sharing options...
peej410 Posted April 21, 2003 Author Share Posted April 21, 2003 i dont quite understand what your asking?, the bottom of the floors are higher and i used a smaller tube then most do but compensated with a slightly thicker steel, if this is superior or inferior ive yet to find out, i tried keeping everything as simple as possible without making compromises in strength. being a fabrication novice its hard to draw the line, but if you have any questions and/or would like some pictures shoot me an email at peej410@aol.com -pete Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted April 21, 2003 Share Posted April 21, 2003 Looks pretty good, are you running a continuous bead of weld on both sides? I did my pans about a month ago and man did it seem to stiffen the car up just a bite, being made out of heavier gauge than stock. Hope your other one goes as good if not better. I figured that someone could fabricate your own floor pans without a problem. Quote Link to comment Share on other sites More sharing options...
peej410 Posted April 21, 2003 Author Share Posted April 21, 2003 Looks pretty good, are you running a continuous bead of weld on both sides? I did my pans about a month ago and man did it seem to stiffen the car up just a bite, being made out of heavier gauge than stock. Hope your other one goes as good if not better. I figured that someone could fabricate your own floor pans without a problem. i ran full beads but i alternated spots to keep from warping the sheetmetal now im building an A -frame to hold the front of the car about 5 feet in the air so as to simplify painting the undercarriage and what not Quote Link to comment Share on other sites More sharing options...
