Gauge Question
Here it goes. Is their any way to adept aftermarket sensors for oil and temp to read from my 350 SBC and display on my stock datsun gauges? I lost the sensors when I moved and now need to make the gauges work. Ive been scouring ebay and classifieds however I would like other options. The fact that I will still have to adapt the datsun sensors to the 350 SBC is annoying. Is their any other option without having to purchase aftermarket gauges?
Btw motor is a carbureted 350 mild cam intake porting on heads. Jtr radiator.
The temp sender was easy, get a TS198. It has a 1/8" pipe thread so all you need from there is a 1/2" X 1/8" bushing or a 3/8" X 1/8" bushing for the intake manifold. The TS198 reads correctly with the stock gauge.
The oil pressure will need to be sender from the Zcar. The Z's oil sender is a 1/8 BSP that is 1 thread count from our 1/8" NPT. I used a 1/8" NPT close nipple and a 1/8" NPT coupling and then used teflon tape as JTR recommended.
Thanks for the quick replys. Dave about the ts198 which temp rating am i looking for? M1noel I would like to have used my stock sensors but the problem is that I lost mine. So im trying to find parts that are easier to source.
Just buy a TS198, its the part number for a temp sender from a Jeep and I think its also for a Toyota. The TS198 is ready to use as is. Just connect it to the wire that was connected to the stock Z's sender. It won't get any easier.
I have found no other solution for the Z's oil sender than use the stock one. I may have a extra if you need one, just PM me.
