nbesheer Posted October 17, 2007 Share Posted October 17, 2007 Okay so I got my set of tokico struts and springs. Well anyways on the front it came with a gland nut and a washer, now with the washer the gland nut does not seat completely like this Now I tightened both of them pretty tight but the front right was making clunks so I looked and the nut was really loose. What should I do, remove the washer and torque the nut down or leave the washer and torque the nut down ? Sorry for the image quality. Quote Link to comment Share on other sites More sharing options...
ihavearustedz Posted October 17, 2007 Share Posted October 17, 2007 dont use the spacer, my 77 didnt need it. dunno what year your putting it on http://www.atlanticz.ca/zclub/techtips/suspension/tokicoupgrade/tokicoinstallfront.htm Quote Link to comment Share on other sites More sharing options...
nbesheer Posted October 17, 2007 Author Share Posted October 17, 2007 Okay I think did a few things wrong first off, I've never done suspension before and the tokico kit did not come with instructions. What is he filling the strut tube with I did not put that "Oil" in and I will remove the spacers when time permits, mean while it's bum-a-ride-time. So first off what kind of oil is that and where do I get it. Second off is it needed for tokico HPs on a 83 280ZX ? Quote Link to comment Share on other sites More sharing options...
Zmanco Posted October 17, 2007 Share Posted October 17, 2007 I believe the oil is primarily there to transfer the heat generated by the up/down motion of the strut to the strut housing more efficiently so it can be dissipated. On my 73 I used Marvel Mystery oil mainly because I had it in the garage when I needed it. I imagine any oil that's reasonably thin will do. As for your question if it's needed on an 83, I don't see why not, but I'll leave that to someone who owns a ZX. Quote Link to comment Share on other sites More sharing options...
ihavearustedz Posted October 17, 2007 Share Posted October 17, 2007 zmanco is right the oil is just a heat transfer. i bought the cheapest 10w30 from autozone. it wouldnt hurt to use it. only used about half a quart for all 4 corners. i dont own a zx so i also dont know about the spacer. but i posted that showing that it wouldnt be unusual if you didnt need it Quote Link to comment Share on other sites More sharing options...
Zmanco Posted October 17, 2007 Share Posted October 17, 2007 BTW, with regard to the clunk, you should also make sure you have the springs properly seated in the top perch when you set the car back down. Like you, I had one gland nut work loose. But after I tightened it I still had a clunk. Turns out one of the rear springs wasn't seated right. Took me way too long to figure that one out Quote Link to comment Share on other sites More sharing options...
rztmartini Posted October 17, 2007 Share Posted October 17, 2007 I think you could actually just use antifreeze around the inserts as a heat transfer also...might want to use straight antifreeze so it dont start rusting... Quote Link to comment Share on other sites More sharing options...
nbesheer Posted October 17, 2007 Author Share Posted October 17, 2007 Well I just ended up using some Penzoil 30w we had in the garage, man it only takes a little to fill it up with a strut. Now I need to get a wrench for the gland nut and hopefully that quiets everything down. Quote Link to comment Share on other sites More sharing options...
