lowdown Posted October 29, 2007 Share Posted October 29, 2007 I need some small brackets to convert my sway bar heim joints to bolt onto the control arms, like these... Anyone know where to get some? Quote Link to comment Share on other sites More sharing options...
olie05 Posted October 29, 2007 Share Posted October 29, 2007 chassisshop.com has a bracket that will do just what you want, you just have to make your own links. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 29, 2007 Share Posted October 29, 2007 I would suggest that you don't use those, or at least that you check for bind after you install them. The problem is what recourse you'll have if they do bind up. Can you make brackets and weld them where they need to be to fix the bind? And if you can, why not just buy the rod ends and make the brackets instead of buying the kit that's been posted, since I'm sure they'd be cheaper if purchased separately. If you read this swaybar mod thread, you'll see I had to get everything lined up just right to prevent the swaybar from binding. If you just bolt that piece on I think it will be bound up really bad. I don't know that for sure, but that's my hunch. http://forums.hybridz.org/showthread.php?t=105596 Quote Link to comment Share on other sites More sharing options...
