Guest GaryZ Posted December 10, 2002 Share Posted December 10, 2002 New to this forum, but am very impressed with the expertise of its members! Does anyone know a source for solid differential mounts? I know MSA sells the front, but can't seem to find a source (Ground Control is out of stock) for the rears. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 10, 2002 Share Posted December 10, 2002 Gary.. diff mounts were just re-visted a short time back do a search function and you may hit a gold mine of diff mount applications.These web pages may work for you.]web page[/url] web page web page These have exceptional merit Quote Link to comment Share on other sites More sharing options...
Synlubes Posted December 10, 2002 Share Posted December 10, 2002 Jim Cook Racing has a very nice aluminum solid diff mount! I`ve been using mine for 6+ years and have not had any problems with it!!! JCR web site Quote Link to comment Share on other sites More sharing options...
Guest GaryZ Posted December 10, 2002 Share Posted December 10, 2002 Thanks for the info, but I guess I should have been more specific: ...was looking for commerical sources for the mounts---and more particularly, a source for the moustache bar mounting points. Quote Link to comment Share on other sites More sharing options...
Synlubes Posted December 10, 2002 Share Posted December 10, 2002 Both MotorSport Auto and Jim Cook Racing are commercial souces! As well as others. They both sell a solid frt mount and they both sell the "solid" bushings 4 the mustache bar mounting! Hope i`m on your same wave link! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 10, 2002 Share Posted December 10, 2002 Someone has been marketing a solid mount on eBay under Datsun/suspension parts and new bushings surface for sale on a regular basis. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted December 10, 2002 Share Posted December 10, 2002 Why do you want solid mounts on the mustache bar? The solid front mount has it’s advantages (since the stock ones break so readily), but what will you pick up by using solid vs. urethane bushings on the mustache bar? Quote Link to comment Share on other sites More sharing options...
Guest GaryZ Posted December 10, 2002 Share Posted December 10, 2002 First, I should point out the car is used in E-Production racing, and solid mounts are probably not the best idea for street use. I think the best analogy for this, I read elsewhere on these forums: it would be like using solid motor mounts on one side and rubber on the other side. The side (or end) that can move, will, and the flexing will tend to do structural damage to whatever its mounted .... at least that's been my experience with the E-Prod car. Although we did consider the argument that poly or other hardened mounting points might "soak up" some of the shocks to the diff, it doesn't seem to work out that way in practice. Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 11, 2002 Share Posted December 11, 2002 i ran a solid mount behind my four speed v8z for a while with no problems, then after a few months, the problems started. driveshaft bolts would come loose every week and once they snapped. once i had driveshaft bolts back in, snapped the mustache bar in two. renew mustache bar bushings with poly and try it again. snapped bolt to said solid mount. new bolts lets try it again, plus strap the nose down per jtr method with a snubber in the trans tunnel over the nose. X-member split in half. weld it back up. split it again right now the middle in a different place. no solid diff mount for me. Quote Link to comment Share on other sites More sharing options...
Guest GaryZ Posted December 11, 2002 Share Posted December 11, 2002 Thanks guys for all the info. Doug: sorry, but was attempting to respond to more than one post at the same time! MSA does not sell solid ones for the moustache bar. Finally located some at Top-End Performance. . .a little pricey, but less than having the race shop fabricate some. Gary Quote Link to comment Share on other sites More sharing options...
