LeX Posted November 12, 2007 Share Posted November 12, 2007 Doing a budget but effective turbo build. Let me know what you guys think and what could be improved keeping it as a budget build motor: L28E , 78 , rebuilt with OEM parts 8.3:1 compression, dished pistons $0 turbo: holset hy35w (he351) @ 1 bar boost $325 injectors: RX7 redtop 450cc injectors $40 fuel pump: MSD inline $100 fuel rail: Pallnet O-ring style $110 FMIC: 24x12x3 core , 2.5 in and out $65 Full Engine Management (MEgasquirt or Emanage or other) $300? 3" full turboback exhaust $275 STI boost gauge $40 non EGR intake manifold $50 stock turbo exhaust manifold $50 turbo valve cover (+30 hp) $10 eclipse 1G Blow off Valve $34 TOTAL COST NOT INCLUDING i/c piping, tuning, fittings and lines $1399 looking for a safe street tune for 93 octane. What do you guys think is the most boost i can run safely for the street with a good tune. I was thinking 1 bar to be safe-ish. -Alex Quote Link to comment Share on other sites More sharing options...
JSM Posted November 12, 2007 Share Posted November 12, 2007 From my research, I would at least double the amount for Megasquirt. Unless you plan on building it yourself. Do you have most of these parts already? 50 for the intake can be questionable. I've seen them go for 42 to 125. Was your "not including fittings" line, including modification of the oil Pan? Just double the figure and I would think you would be safe. Quote Link to comment Share on other sites More sharing options...
ktm Posted November 12, 2007 Share Posted November 12, 2007 "Full Engine Management (MEgasquirt or Emanage or other) $300? 3" full turboback exhaust $275" I would double the cost for MS as well. Additionally, I highly doubt you will be getting a 3" turbo back exhaust (mandrel bent) for only $275. You forgot a muffler which in itself is $65 to $150+. The FMIC is a little low as well. I know you are probably quoting an Ebay SSAC I/C, but you have to figure in shipping too. I would budget $100 for the I/C. The turbo valve cover is not $10, more like $50. You need to have the injectors bench flow tested and cleaned if they are used. Figure another $80 for the injectors. These are but a few examples. If you purchase all new bolts for the engine, figure another $100. Powdercoating engine parts, figure another $200. You need a new fuel filter and those run $50 minimum. What about a fuel pressure regulator? An Aeromotive FPR will run you around $150. Fuel pressure gauge is another $40. An intake (piping and K&N filter) will run you another $70. I agree with JSM. Double your figure for a safe estimate of a 'budget' build. Quote Link to comment Share on other sites More sharing options...
1 fast z Posted November 12, 2007 Share Posted November 12, 2007 I have megasquirted cars for under 300.00, thats for everything. Harness is 65, MS1 V2.2 is 220, and solder, etc, works out to under 300.00. Max I have ever megasquirted a car was 500 for MS2 and wiring harness. BTW, I have megasquirted 10 vehicals now. Quote Link to comment Share on other sites More sharing options...
LeX Posted November 12, 2007 Author Share Posted November 12, 2007 everything with a price by it has already been purchased for the price listed. I might get an emanage ultimate... I can get one installed for 425 Quote Link to comment Share on other sites More sharing options...
LeX Posted November 12, 2007 Author Share Posted November 12, 2007 "Full Engine Management (MEgasquirt or Emanage or other) $300? 3" full turboback exhaust $275" I would double the cost for MS as well. Additionally, I highly doubt you will be getting a 3" turbo back exhaust (mandrel bent) for only $275. You forgot a muffler which in itself is $65 to $150+. The FMIC is a little low as well. I know you are probably quoting an Ebay SSAC I/C, but you have to figure in shipping too. I would budget $100 for the I/C. The turbo valve cover is not $10, more like $50. You need to have the injectors bench flow tested and cleaned if they are used. Figure another $80 for the injectors. These are but a few examples. If you purchase all new bolts for the engine, figure another $100. Powdercoating engine parts, figure another $200. You need a new fuel filter and those run $50 minimum. What about a fuel pressure regulator? An Aeromotive FPR will run you around $150. Fuel pressure gauge is another $40. An intake (piping and K&N filter) will run you another $70. I agree with JSM. Double your figure for a safe estimate of a 'budget' build. I already have the turboback, turbo valve cover, no muffler on car, 3" resonated with tip (mufflers kill the amazing Z car sound ) already have FMIC , already painted some engine parts with engine enamel . Having the emanage i suppose control fuel adn everything else. Have a fuel pressure gauge and already have an intake. I also have a fuel cell and have newer fuel filter Quote Link to comment Share on other sites More sharing options...
LeX Posted November 12, 2007 Author Share Posted November 12, 2007 From my research, I would at least double the amount for Megasquirt. Unless you plan on building it yourself. Do you have most of these parts already? 50 for the intake can be questionable. I've seen them go for 42 to 125. Was your "not including fittings" line, including modification of the oil Pan? Just double the figure and I would think you would be safe. right modification of oil pan i would include with fittings and etc i suppose Quote Link to comment Share on other sites More sharing options...
JSM Posted November 12, 2007 Share Posted November 12, 2007 Cool, let us know how she turns out. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted November 13, 2007 Share Posted November 13, 2007 Don't forget to add a wideband to your list. Quote Link to comment Share on other sites More sharing options...
LeX Posted November 13, 2007 Author Share Posted November 13, 2007 Don't forget to add a wideband to your list. yeah ur right! i will get one stuck in as soon as i take it over for tuning Quote Link to comment Share on other sites More sharing options...
LeX Posted November 13, 2007 Author Share Posted November 13, 2007 what do you guys think would be a safe level of boost to run on the street, 93 octane tuned properly with the above mods. I was thinking a max of 1 bar boost (14-15psi ish) but some folks have told me they ran 18 on theirs. 18 just seems a bit high on a non turbo but it is the 8.3:1 comp one.. i know the pistons aren't so much the issue as the rings and seals and all that junk. What do you guys think Quote Link to comment Share on other sites More sharing options...
slownrusty Posted November 14, 2007 Share Posted November 14, 2007 8.3:1 CR with OEM cast pistons and 15psi...better hope that motor is tuned to an inch of its life. eManage and full stand alone EMS are worlds apart.... Yasin Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted November 14, 2007 Share Posted November 14, 2007 I'd agree about the eManage versus standalone, but since the limiting factor is the pistons, or namely the piston rings, a lot of it boils down to keeping it from detonating. If you can do that, you can get more out of it before the power breaks the ringlands. That's the reason for the engine management comments and whatnot. Keep the A/F safe and/or run some octane booster (as in, a gallon of race fuel per tank or torco additives, etc.; not the useless garbage at auto parts stores) to try to suppress detonation until you get a longer term solution. I'd recommend a clean standalone like a megasquirt and EDIS, etc. Quote Link to comment Share on other sites More sharing options...
LeX Posted November 14, 2007 Author Share Posted November 14, 2007 yeah definitely going to run megasquirt now, seems the only smart choice. Quote Link to comment Share on other sites More sharing options...
