timek1m Posted November 14, 2007 Share Posted November 14, 2007 ok, got a question for those who did the 240sx caliper swap and i want to know what brake lines im suppose to use? can the 280z stock brake lines work? cuz im about to buy a new set of SS lines frome earl's and i dont know what i should do before i tear apart the rear drum set. if anyone has done this and bought a pair earl's line could you tell me what number or what kind you bought or a SS equivalent. hopefully i wont have to custom make it? thanks. Quote Link to comment Share on other sites More sharing options...
280Z Turbo Posted November 15, 2007 Share Posted November 15, 2007 I'm going to order some custom lines from Modern Motorsports. I almost got some stock 240SX lines from Agency Power, but if you use the stock brake line mounting points, you run the risk of wrecking them on the E-brake arm. The 240SX brake lines also use a banjo fitting, while the stock lines have a female fitting. The Modern Motorsports lines get rid of the hard line on the passenger side, but you will need to modify the hard line on the driver's side. Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted November 15, 2007 Share Posted November 15, 2007 if you use the stock brake line mounting points, you run the risk of wrecking them on the E-brake arm. The Modern Motorsports lines get rid of the hard line on the passenger side, but you will need to modify the hard line on the driver's side. Did that check out my thread. I lived and learned. All is explained over here: http://forums.hybridz.org/showthread.php?p=823998#post823998 Quote Link to comment Share on other sites More sharing options...
