timek1m Posted November 23, 2007 Share Posted November 23, 2007 ok, got a quick question, i have a 1975 280z with a L28 engine i just changed the water pump, radiator, thermostat, and almost every possible gasket for the cooling in the car along with heater hose, and radiator hoses, should the engine be smoking? what could cause it? it looks like it is smoking from under the intake. maybe all the radiator coolant got on something? or not? but it started smoking right after i started te car and it the car was cold before i started it? any ideas? thanks. Quote Link to comment Share on other sites More sharing options...
bucket240z Posted November 24, 2007 Share Posted November 24, 2007 head gasket? Quote Link to comment Share on other sites More sharing options...
naviathan Posted November 24, 2007 Share Posted November 24, 2007 I'd have to say either residual that's just burning off as the exhaust heats up or it could be the headgasket. Let it run for a while and see if it overheats or the smoking stops. Quote Link to comment Share on other sites More sharing options...
timek1m Posted November 24, 2007 Author Share Posted November 24, 2007 alrite ill give it a try. thanks. Quote Link to comment Share on other sites More sharing options...
2savage Posted November 27, 2007 Share Posted November 27, 2007 As suggested it could just be all your oily finger prints on the headers and such. If it's coolant then it will be steam, not smoke. This will be whitish and will not continue into the atmosphere for long. In contrast, oil burn-off is blue and remains visible. If it's oil then the only places it can come from is by bypassing the oil control ring of pistons (worn bores or oil control rings) or by getting past the oil seals of the valves. This is caused by worn valve guides or oil seals. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Thumper Posted November 27, 2007 Share Posted November 27, 2007 Also check your oil dipstick. If its milky color than possible blown headgasket. If its good oil color than most likely just stuff burning off. Also check to make sure your thermostat housing isn't leaking. Quote Link to comment Share on other sites More sharing options...
timek1m Posted November 28, 2007 Author Share Posted November 28, 2007 alrite, been busy so havent got around to the car will do this friday. now that i think about it, the info you guys gave is great. i dont think it was steam it was smoke. i have a feeling its a gasket... i know it isnt the thermostat housing. that is for sure i double checked that make times. but will do on friday thanks. again its a good think im still getting feed on this. gives me more to think about. thanks again. Quote Link to comment Share on other sites More sharing options...
