aarang Posted December 7, 2007 Share Posted December 7, 2007 Help!!, My EFI relay went dead so of course my car is dead, too. Does anyone have an extra? It is the green plastic one for the 83 ZXT EFI. Hopefully I posted this in the right spot. Thanks in advance. Aaron Quote Link to comment Share on other sites More sharing options...
Thumper Posted December 7, 2007 Share Posted December 7, 2007 Help!!, My EFI relay went dead so of course my car is dead, too. Does anyone have an extra? It is the green plastic one for the 83 ZXT EFI. Hopefully I posted this in the right spot. Thanks in advance. Aaron You can get it from Nissan. FYI you should post this in the for sale/wanted area. Also if you just need to drive your car a short distance and you don't mind catching your car on fire you can always jump the connectors. But if your relay burned out for a reason then you will cause a fire. Good luck. Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 8, 2007 Share Posted December 8, 2007 You should be able to use any 280zx relay in it's place... It's green to make it easier to find. Quote Link to comment Share on other sites More sharing options...
aarang Posted December 8, 2007 Author Share Posted December 8, 2007 I actually removed and tested the relay, no power going through it when activated, so it is no good. Harness is fine. I have three other EFI relays from various 280ZX's, but not one of them is the same. I was just hoping someone had an extra. Nissan has them, but at $80, I'd rather find used. If someone knows the amp rating of this relay LMK, I'll just wire in a new Bosch relay instead and save myself the money! Thanks for the replys. Aaron Quote Link to comment Share on other sites More sharing options...
badjuju Posted December 9, 2007 Share Posted December 9, 2007 30 amp is probably a good guess. Quote Link to comment Share on other sites More sharing options...
