Bottoming out
Well, besides figuring the struts are not up to the task of the springs, I also find out that the springs themselves are bottoming out on their own coils, take a look:
http://docmudge.tripod.com/Z_struts/struts.html
Any suggestions as to how to fix this? Should I cut a couple coils? Even with good strut inserts the spring is going to be bottoming out on itself from time to time, and this is not a good thing at high speeds... :(
Since the springs are blue I'm guessing they are Suspension Techniques or maybe Tokico, anyone know? STs I have on the other car are blue...
Looks like the "spring" got up and walked on those coils.I doubt if cutting coils would help on that much compressed sag. Looks like they were heated to bring the coils together for a lowering job. The only suggestion that I doubt would work is to heat and re-stretch. Change them to anything would be an improvement
Mudge, the pictures on my end of cyber space show at least 4 coils touching at the bottom which means there "are no a bounce in the re-coil in that stack". After reading a lot of posts it apppears that lowering springs generally suffer from low quality and bottom out too early in a short life span. I have never seen lowering spring ad copy that came forward with any definite spring load capacity figures. MSA sells 4 types but dies not pinpoint the weight capacity.
Yep, a few are not only already touching, but the others have hardly any space between, and there are so many coils altogether that they just get in each others way very much too early, there is hardly any travel before they will bottom out with each other.
Normally aftermarket springs will have a couple fewer coils than stock, so I'm beginning to fear that they really may be torched, but I'd still be a bit supprised, I thought only kids did that nowdays.
The stock spring diameter is 4 3/8"
Here is some info on stock springs and
how I arrived at it.
SPRINGS
front springs are different in the 71 right spring is longer.
Rear springs are the same.
FRONT SPRINGS 71-73 24OZ
Wire Size-----------.425
Spring Length------15 1/4" Right side, 14 3/4" Left side
Spring Rate---------1OOlb
REAR SPRINGS 71-73 24OZ
Wire Size-----------.452
Spring Length------15" Both sides the same
Rate-----------------13Olb
FRONT SPRINGS 2+2 75Z
wire size----------.458
Spring Length------15 3/8" Both the same
Rate----------------145lb
To check spring rate use a bathroom scale and
a drill press. Put the spring holder on the top
of the spring and a couple pieces of wood on
the scale and put pressure till you hit 5Olbs
on your scale then set the inch dial on the
drill press to 1,2,or what ever then from the
5Olbs point apply one dial inch worth of
pressure and what your scale reads will be
your spring rate!
Thanks Dave! Doesn't sound like a very easy to find size, but if I can find some springs in that OD that would rock, so I will try to find some.
No springs yet for ID of 3.525"/OD 4.375"... still lookin'.
I dont suppose anyone knows offhand if other cars share the same OD/ID?
FWIW, the Haynes says for 240Z:
Front Spring
Wire Diameter .417" (10.6mm)
Coil diameter 3.94" (100.0mm)
10 coils
Free length
Left side 14.1" (373.5mm)
Right side 15.1" (386.0mm)
Rear Springs
Wire Diameter .449" (11.4mm)
Coil Diameter 3.94" (100.0mm)
Number of coils 10.65
Free length 15.0" (381.0mm)
Although since the Haynes is the English version, not sure it will be the same as US spec.
Hmm, I do have a full set of 240Z (presumed,came from a 240Z customers car) 'light blue' springs/used. He never ran it with the springs, they're uncut and perhaps Tokico's? I've also got a set of black (MSA?) springs, I have the fronts and customer still has the rears but he can get them to me no worries. The blues are available now to anyone wanting a 'get by' set (they might be fine/I'm just not a fan of them.......their's a reason my customers keep turning them in).
Drop me a line if interested.
  • 4 weeks later...
Well, pulled the fronts a few days ago (haven't done rear yet), and the springs are 11.5" FULL LENGTH, and still the stock # of coils. So, definite torch job.
I have stockers on with 1.5 coils cut right now, definately sits a bit higher, and unloaded length was ALOT more than the ones that came off the car. Mine sit about 13" unloaded (fronts), versus the 11.5" jobbers.
