big-phil Posted December 30, 2007 Share Posted December 30, 2007 I've got outputs 1 & 2, but for 3 & 4 where is "pin 15 of the uP"??? and LED 18 - D15? where the heck is that? this is for ms1 v3.0 is it js1, and js0?? the 2 right under the source for outputs 1 & 2 (js2 & js3) Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted December 30, 2007 Share Posted December 30, 2007 Look at your V3 assembly How to.....The LED is one of the led's..haha.. I think the other is pin 15 on the processor.... Not 100% though...just did a quick look... Quote Link to comment Share on other sites More sharing options...
z-ya Posted December 30, 2007 Share Posted December 30, 2007 What are you trying to do? Quote Link to comment Share on other sites More sharing options...
big-phil Posted December 31, 2007 Author Share Posted December 31, 2007 z-ya said: What are you trying to do? Just want to hook #3 to my make shift cold start vaccumm operated thing. as of now output #1 goes to my fan #2 is my shift light I don't really need #4 but want to have it when I need it. Quote Link to comment Share on other sites More sharing options...
z-ya Posted December 31, 2007 Share Posted December 31, 2007 Do you mean an IAC? Are you using the fidle output for your coil? If not, use that to control your IAC relay. Quote Link to comment Share on other sites More sharing options...
big-phil Posted December 31, 2007 Author Share Posted December 31, 2007 I'm using the A/C vacuum idle up thing connected to a relay vac. switch. right now I have it hooked to a toggle. see this video: Quote Link to comment Share on other sites More sharing options...
Careless Posted December 31, 2007 Share Posted December 31, 2007 Fast-Idle output would be LED17, correct? Haven't used MS in a while. Quote Link to comment Share on other sites More sharing options...
big-phil Posted January 4, 2008 Author Share Posted January 4, 2008 I don't have a fast idle, I should go that way. but for now I just need to turn a relay on and off at a set temp basically. And maybe one more output to control my meth? Are outputs 3 & 4 different from 1 & 2? 1 & 2 hooked up easy. Quote Link to comment Share on other sites More sharing options...
