Another Blown Fuse Thread
CArFAn
I'm like a complete dumb-ass when it comes to electrical stuff. There is a fuse that blew in the fuse box its a buss type fuse and on the top of it it says "Buss AGC 2" and the opposite end says "250 VOLT" i have some that i can replace it with and one says "15A32V" and th other side "311 3AG" and the other says "307 SFE" and the opposite end says "20A32V". Which one do i use to replace it?
It happened when i forgot to disconnect the battery and i touch this little "prong like thing" (comes from the turn signal switch and sticks out and rubs against the back of the wheel) to the steering column . It sparked a bit and i heard something make like a click noise because i dropped it and it touched something else i don't know what it was. So i look at the fuses and one was blown.
This one its a 1972 240z:
thats a 10 amp fuse... I guess you could use the 15 amp fuse you have untill you get a 10 amp one but thats probably not the best idea
20A32v = 20 amp 32 volt I think? go with the 311 3AG fuse (standard car fuse ... I think?)
that side of the fuse block is (starting from the top) 10a, 10a, 20a, 10a, 20a
Matt-
