another brake bleeding problem!
first, i want to say i did search but couldn't find any threads with similar symptoms.
alright, heres the deal, calipers, drums, stainless steel brake lines are all new. i've bled the brakes so that absolutely no air is in the lines, the pedal has pressure but it doesn't come to a stopping point when max pressure is acheived, it just goes to the floor. all threads look to be just fine and all flares are at the SAE standard of 37 degrees. can somebody please help me?
ps: i'm also having a similar problem with the clutch but i'll post that in the drivetrain thread, so if any of you hydraulic gurus could also please check that out for me also please it would be much appreciated.
If your sure you used a 37 degree flare, You've used the wrong flare.
A double or inverted flare is a 45 degree flare the one you used sounds like an AN type.
Since your also having the same problem with the clutch, I would check all of your new fittings for leaks.
