gildia Posted January 13, 2008 Share Posted January 13, 2008 I am rebuilding a 72 240z and i am starting with the electrical, but the harness has had some abuse and it doesn`t have the fusible links, can i replece them with a normal fuse? Quote Link to comment Share on other sites More sharing options...
naviathan Posted January 13, 2008 Share Posted January 13, 2008 Search on Maxi Fuse and you should find lots of information on replacing the old fusible links. Quote Link to comment Share on other sites More sharing options...
Clifton Posted January 13, 2008 Share Posted January 13, 2008 You can buy fusible link wire or get a high amp fuse. Any local auto parts store carries them. Some have a ma;e push on connector. That's what I did one mine. They look like this but this is a bolt in style. Quote Link to comment Share on other sites More sharing options...
gildia Posted January 15, 2008 Author Share Posted January 15, 2008 Thank You guys, i´m goign to try to get the fuses you mention and replace them, i´ll let you know how it goes, by the way do you know what is the amp or the sible links, so i can get the right fuses Thank you Quote Link to comment Share on other sites More sharing options...
naviathan Posted January 15, 2008 Share Posted January 15, 2008 That can also be found by searching. Search for "fusible link wire color" and it should pull something. Quote Link to comment Share on other sites More sharing options...
yogib Posted January 16, 2008 Share Posted January 16, 2008 http://www.zcarcreations.com/howto/maxifuse.htm Try this Quote Link to comment Share on other sites More sharing options...
