Dallas J Posted January 20, 2008 Share Posted January 20, 2008 I have a 73 240z with a 2.8l and 5speed from a 75. The clutch in it is slipping and with my other project I can afford to buy a better clutch. What disc should I be looking for? The auto parts store was saying something about a 75 2+2 and a ZX, each one having a different clutch diameters. Being a 240z newb, Im not sure which to get. I want to be able to just get a disc to swap in (just a quick $50 fix) until after I finish my SM DSM, then I can figure out what I want to do with the car. Quote Link to comment Share on other sites More sharing options...
primer&rust Posted January 20, 2008 Share Posted January 20, 2008 If the flywheel is from a 2+2 you will most likely have a 240mm flywheel and need that clutch disc sized for it. If it was from the 2 seater it is most likely a 225mm flywheel and need the clutch size for it. The pressure plates also have different bolt patterns depending on which flywheel they bolt to. The only way to know for sure is to tear it down and match it with the clutch disc you need either through pictures or at a parts store. With the mix and match setup you already have that is the best advise I can give. Or if you have enough cash buy both clutch disc and return the one that wil not work with your setup. Quote Link to comment Share on other sites More sharing options...
Dallas J Posted January 20, 2008 Author Share Posted January 20, 2008 Thats what I was afraid of. I guess Ill just drop the tranny one weekend and when I find out what it is see if I can get it locally quickly. Any tips on what will give it away obviously other than just measuring the disk itself? Quote Link to comment Share on other sites More sharing options...
steveosupremeo Posted January 21, 2008 Share Posted January 21, 2008 if the pressure plate has 9 bolts holding it on its a 240mm or 2+2, if it has 6 bolts holding it on its a 225mm or coupe disc. Quote Link to comment Share on other sites More sharing options...
Dallas J Posted January 21, 2008 Author Share Posted January 21, 2008 if the pressure plate has 9 bolts holding it on its a 240mm or 2+2, if it has 6 bolts holding it on its a 225mm or coupe disc. Thats good info , thanks. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted January 25, 2008 Share Posted January 25, 2008 what year model did the 2.8 engine come out of that will tell you what clutch plate to look for. As said above flywheel from 2+2 or a turbo takes the 240 mm clutch. If you can find a 240 mm flywheel at the junkyard I would go with that as you have more contact area. Quote Link to comment Share on other sites More sharing options...
Dallas J Posted January 26, 2008 Author Share Posted January 26, 2008 When I was looking up the head code (which id have to look at again cause I forgot), but the code was for a 75 so thats what i've been assuming the rest of the swap came from. Quote Link to comment Share on other sites More sharing options...
