Datsun260Z Posted January 31, 2008 Share Posted January 31, 2008 Evenin' Z friends.... so today was a pretty special day. As I shared in another thread my Z has been a long time coming as a project. As of late I have been learning Machining and have had the opportunity to perform some of the machine work to my L28 with an N42 head. Here's where I am at with my question. I began some preliminary inspections of all the head components - after I finished milling the head my primary focus was the springs. I only measured a few before I stopped. Seems they are 1 MM shorter than what the spec is on them in my manual. I guess what I want to know is, would you change them - or, would you be more inclined to simply make sure they're all equal. Here's where I am at with this motor; some info that might help you help me. I am not building the craziest outlandish motor here. What I am doing is simply cleaning things up. I want a tight motor that runs WELL. I am not looking to race, nor do I want or really care about HP at this time. My budget is tight, I am changing careers and we're having a baby. I enjoy the Z, I do everything myself - for the love of it and that it's really the only way I can have these things at this point. I am sure most of you can relate. Bottom line is, this isn't the last engine I bolt together, I assure you of that and frankly I'd much rather put time and effort and small amounts of investment into a first build...and learn something more about building engines before I get insane and build a stroker or whatever. I think you get the picture. So - would you change these springs....and if you would...what kind of money should someone expect to put out for a set? Thanks for everything, much appreciated as always. tim Quote Link to comment Share on other sites More sharing options...
cjames Posted January 31, 2008 Share Posted January 31, 2008 if it were me, and I had it apart doing other work, Id replace them. I dont know what other work youre doing to the head, but a weak (or broken) spring can screw up all the good work you did in addition to all kinds of other bad stuff. I personally wouldn't reuse "old" valve springs regardless what they measure. L series heads arent cheap to build, Valve springs are cheap compaired to the rest of the parts, and way cheaper than a dropped valve... I think I paid less than $100 for the last set of springs I ordered. Quote Link to comment Share on other sites More sharing options...
Datsun260Z Posted January 31, 2008 Author Share Posted January 31, 2008 if it were me, and I had it apart doing other work, Id replace them. I dont know what other work youre doing to the head, but a weak (or broken) spring can screw up all the good work you did in addition to all kinds of other bad stuff. I personally wouldn't reuse "old" valve springs regardless what they measure. L series heads arent cheap to build, Valve springs are cheap compaired to the rest of the parts, and way cheaper than a dropped valve... I think I paid less than $100 for the last set of springs I ordered. Hey thanks for the thoughts and advice. I am really not doing much more than cleaning things up. I decked the head and that is pretty much what I am going to do. However, less then a 100 bucks...then I think I can make that happen. I thought there were much more than that. Thanks again man, have a good one. T Quote Link to comment Share on other sites More sharing options...
