Guest Anonymous Posted March 16, 2000 Share Posted March 16, 2000 Hey!, I just found a site that's REALLY cool! It's a "design studio" for transmission and rear end ratios...it lets you input your trans and diff gears ratios and tire diameter, then it tells you your rpms and speed in each gear. It works using java somehow and you just mouse over the graph to get the results. REALLY SLICK!!! AND!!! It's designed for Zcars...it has all the rear end ratios for the stock R180 and R200 differentials. But you will have to put in the tranny ratios manually for the GM trannys. Here's the site... http://www.geocities.com/z_design_studio/ Lee Quote Link to comment Share on other sites More sharing options...
MYRON Posted March 16, 2000 Share Posted March 16, 2000 That is a cool site, Can we get it posted to the links on this site? What about it SD Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 20, 2000 Share Posted March 20, 2000 Accorkding to that little gadget, my car will do 245mph at 5990RPM..... WOW!!!!!!!!!!! Big factor is weight, aerodynamics, HP, weather. Interesting little bugger... Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 21, 2000 Share Posted March 21, 2000 Ha...I just put in the numbers for my proposed setup and it says I'll make it to 57 mph at 6000RPM in 1st,86 in 2nd,118 in 3rd,153 in 4th,206 in 5th, and 306 in 6th. I would think that the numbers up through 4th gear are easily achieveable and possibly that 206 in 5th is realistic, but none of our cars will ever see 300 MPH...that is OK with me. I especially like the 70 MPH in 6th gear at 1374 RPM!! SpencZ Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 22, 2000 Share Posted March 22, 2000 The other factor to figure in is the changes in actual tire diameters between brands... I'm gonna upgrade my wheels to 15X10 in the rear and run a Yokohama 285-35-15 in the rear, and a 255-45-15 upfront. But for now I'm stuck with 265-50-15s in the rear and 225-50s up front. That combo is still gonna push some serious numbers with the 3.7 and the T56. Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Guest Carlissimo Posted March 22, 2000 Share Posted March 22, 2000 Mike, I have 265/50-15s on the back with 9" wheels and 245/50-15s on the front with 8" wheels. What size wheels do you have with your tires ? I was thinking about getting some 225/50-15s for my front but am not sure if they would be too small for my 8" wheels. Carlo Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 22, 2000 Share Posted March 22, 2000 Mine are 15X8 wheels and my 225s fit perfect. Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
MYRON Posted March 22, 2000 Share Posted March 22, 2000 Mine are 16x8 with 205/50-16's Z rated.. No clearance problems Quote Link to comment Share on other sites More sharing options...
