Resurection now becoming 1TUFZG Z
Well I'm about to embark on the second build of this car. The first go around began in 1999 and the car kind of got shelved/lost interest in 2004 when I bought the Cobra.
I didn't have a ton of money back in 99-02 to put in the project but now times have changed so here we go with the second coming of the car.
Here is what I’m looking at from the top to the bottom most parts are on hand unless noted.
Fiberglass SS hood
Holley TB/EFI set up
Edelbrock Torker intake with the hidden NO2 set up
Full roller/Full forged 383 c.i. SBC stroker engine
T-5 transmission with *Centerforce DF clutch and Hurst billet shifter
R-200 LSD rear end with custom mounts and brackets + CV axels
Custom MML coil over suspension with Tokico 5 way adjustable struts
Arizona Z car racing brake set up
Sport Max wheels, Fulda Z rated tires 245-50-16 (on the car now)
JDM ZG fender flairs (cut metal fenders to clear the tire+wheel set up!)
Bad Dog frame rails for additional strength
Sump OEM tank with custom built fuel sump
Custom fuel plumbing
Sparco Seats
SCCA roll bar
Sound deaden doors
Few more gauges NO2 pressure A/F meter
Paint and body work
So with out further ado welcome 1TUFZG Z, let the wrenching begin.
Start... or where I quit a few years ago.
New tires and wheels. Sport Max 16X8 with Fulda (Goodyear Germany) 245-50-16
Home at last!!!!
Interior this will change (colors)
Bye-bye bling stuff...
Eagle 4340 crank, H beam rods Mahle pistons balanced.
Had to push the car out of storeage wouldn't start.
At home engine out.
Rear fender taped for cut out for ZG flair.
Drivers side ready for cut.
I've never done this before so it's not pretty :(
Timing gear cover powder coated matte black.
Short block coming along.
Kevko oil pan before coating
Coated.
Unassuming enough....
Bottom side of unassuming, all business...
  • 5 months later...
  • Replies 58
  • 1 month later...
  • 3 months later...
  • 1 month later...
Update.
Floor pans are in seats and roll bar mounted.
Floor pan
Fenders cut for ZG flairs. Need to be raised another 1/2" on the upper arch. Note the nice transition at the bottom of the wheel arch front and back, these guys are doing a very nice job here.
Fuel tank with sump.
Went with the GB wheels Rota RB-R
Engine bay holes have been filled and smoothed
  • 3 weeks later...
  • 5 months later...
  • 2 months later...
Carbon fiber Sparrow tail from Zcar customs. Mocked up on the Scarab (doesn't belong to the Scarab)
Another angle of the Sparrow tail, overall fit is VERY GOOD!!!
Looks a little large in this pic but it's flatter than it appears, remember we're just holding it in place.
Gnose and Sparrow tail avaliable from
Z Car Custom's-JDM
www.zccjdm.com
P.O. Box #213
Terrabonne, OR. 97760
PH. 541-913-6530
azcarbum@msn.com
  • 3 weeks later...
Time for another update. Rear suspension is in. Rear end is LSD with finned powder coated cover, up front we have a OEM Datsun front dif mount with a Ron Tyler bracket bolted in and an Energy Suspension poly mount sandwiched in between. Installing the RT mount was for us a PITA! First the top bolt did not line up with the mount hole, second we had to remove material from the TOP of the ES mount. Well it's in there now, nice and solid.
The furthest rear X member was cut leaving the two bushing retainers, then using another custom piece from my brothers here at hybridz is the bar you see connecting the two sides together. MML coil overs and Tokico 5 ways, everything is powder coated. Enjoy.
Wheels RB-R 17X9.5 -13 Tire Hankook 275-40-17
  • 4 weeks later...
Few more updates, still working on fitment of Gnose.
You can see the bracket that is supplied from the kit
If you want the nose perfect you'll have to do some filling and sanding. If otherwise it is a bolt on nose, we're going for something close to perfect here.
My body guy went area 51, skunk works on the Sparrow tail so it wouldn't get scratched up while working on the rear hatch so no new updates on what it looks like. We do have the RB-R's mounted with 275-40-17 tires and the coil overs cranked down to check for fitment. This is a standard ZG flair.
This is the BAMF flair with a Rota RBR, you need 315's and an 11" wheel to fill this flair out. These are no longer mine but wanted to point out the difference between the two flairs.
  • 4 months later...
  • 2 months later...
  • 5 months later...
An update pics will come later. We had an issue with the powder coating on the rear control arms so they were painted to match the the coating. I sprayed the entire interior with Second Skin sound deadener. The firewall was initially sprayed with Second Skin "fire wall" to soak up the heat, then sprayed with multipule coats of the sound deadener.
Finally it's off to the paint shop where it will be painted Artic White with silver/gray flairs, rear bumper and lower g-nose.
The engine should be est. 500HP FI through a holley TBI. Compression is 11:1 with a snow performance water/methanol injection set up. NOS wet shot is 100HP.
Ignition MSD e-curve distributor. Mechanical roller cam which is gear driven. Forged pistons, H-beam rods 4340 crank all balanced.
Really looking forward to a new and much improved V-8 Zcar experience.
  • 2 months later...
