Can someone replace the CLSD ring gear?
VinhZXT
Buy a used R200 and swap the LSD into the new unit. Info on the swap procedure here: http://forums.hybridz.org/showthread.php?t=119990
As a rule you should NEVER mix rings and pinions, even if they're the same ratio. They get matched to each other during the manufacturing process and are not interchangeable.
