JSM Posted February 10, 2008 Share Posted February 10, 2008 The top tube in red is the return line on a 73 tank correct? Thanks! Quote Link to comment Share on other sites More sharing options...
JSM Posted February 10, 2008 Author Share Posted February 10, 2008 Pop N Wood said: The factory return runs all the way back to the tank. There are two penetrations in the tank, the 5/16 supply and 1/4 return. Each has it's own hard line with a short section of rubber hose connecting the tank to the hard lines. Both tank penetrations are right next to each other. There is also a third 1/4 inch line that is a tank vent. On my California edition 70 model it goes from a vapor recovery tank in the right rear C pillar up to the crankcase/intake manifold. Are you sure this isn't the line that was pinched off? I completely removed that line from my car. Looks like I found my answer in this post thanks. Should have searched first. http://forums.hybridz.org/showthread.php?t=119492&highlight=return+line Quote Link to comment Share on other sites More sharing options...
X64v Posted February 10, 2008 Share Posted February 10, 2008 I will confirm that that is indeed the stock return on the '73s. Quote Link to comment Share on other sites More sharing options...
Tony D Posted February 11, 2008 Share Posted February 11, 2008 Yes, the 3/16 line is the return. If you are considering EFI, don't use that for the return, use one of the 1/4" vent lines, the small one will cause some fuel pressure control issues if used with even a stock EFI pump... Quote Link to comment Share on other sites More sharing options...
