Driveshaft lengths?
Guest Frank280z
Guest Frank280z
JTR kit with Hei dist. 1/2 from the firewall. Backed by a 4 spd Muncie. How do I measure for the driveshaft? Is it comparable to the length that the book recomends for a th350?
Frank280z
With the engine and trans installed, a slip yoke slid all the way into the transmission, and the differential/driveshaft adapter bolted to the differential, measure the distance between the center of the u-joint cup hole in the slip yoke to the center of the u-joint cup hole in the driveshaft adapter on the diff. Then subtract 3/4" from that figure. That is your center-to-center driveshaft length that the fabricator needs.
Guest mattrp
Mine was also 19 3/4". I measured with about 1/2 to 3/4" extra slide in the yoke into the tranny. So i guess the swap to the t56 wont require a new drive shaft. Hehehe
Matt
72 500Z
