nbesheer Posted February 19, 2008 Share Posted February 19, 2008 Well i just bought some Redline MT-90 for my 152k NA 5-Speed and I'm just hoping that I got the right one because it's going to be a pain to exchange it since the dealer is kinda far away. I believe I need either MT-90 or MTL it appears that the only different is MT-90 is 75w90 and MTL is 70w80 I currently have cheap fluid. Quote Link to comment Share on other sites More sharing options...
TimZ Posted February 19, 2008 Share Posted February 19, 2008 As I recall, either one should work just fine. The MTL will probably shift a little bit smoother than the MT-90, but the MT-90 will give better protection against shock loading, so it's more appropriate for applications with increased power. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 22, 2008 Share Posted February 22, 2008 The GTR boys swear by Lightweight Shockproof, I'll be using it in the Z32 box. For ordinary use either the MT or MTL should be good, as Tim described. Quote Link to comment Share on other sites More sharing options...
john turner Posted February 22, 2008 Share Posted February 22, 2008 Have used both Redline MTL, and MTL 90 in my s30 5-speeds. Had fluid leakage problems with MTL when I had never had the problem with conventional gear oils, or for that matter MTL 90. The oil loss led to. I believe, premature bearing failure.......took me two transmission rebuilds to figure the problem out. Painful to think about being so slow on the uptake. Am currently using MTL 90 on my extended mileage transmission........and swear by it.....not at it. Regards, John T. Quote Link to comment Share on other sites More sharing options...
nbesheer Posted February 22, 2008 Author Share Posted February 22, 2008 Well I was going to do it yesterday buy someone torqued the fill plug on real tight and couldn't get it off and I even placed a wrench on it and lowered the car to the ground and it didn't break loose. so off to the welder we went. Quote Link to comment Share on other sites More sharing options...
