Guest jrome Posted February 22, 2008 Share Posted February 22, 2008 i have a 76 280z that has a miss when its warmed up . i started it cold and tried to drive it and it seemed not to miss when the cold start is operating. i have no clue why but its so annoying to drive like this. when i floor it, it runs fine . pulls right through the rpms no problem. ive replaced the plugs, cap, rotor button, fuel filter, coolant temp sensor, air filter, checked gas for rust and it looked great. im stumped and need some help. Quote Link to comment Share on other sites More sharing options...
woldson Posted February 23, 2008 Share Posted February 23, 2008 So dose it miss then at a steady throttle? If so dose it studder at steady 3000rpm? Quote Link to comment Share on other sites More sharing options...
Guest jrome Posted February 23, 2008 Share Posted February 23, 2008 it stutters like if i just take off from a stop . when i just give it gas easy . it just feels like its not getting any gas . it pops a little and sputters. but if i floor it . or take off at about half throttle it is fine. Quote Link to comment Share on other sites More sharing options...
woldson Posted February 23, 2008 Share Posted February 23, 2008 Dose this also happen when reving the engine under no load. My quick guess is the mass air flow sensor, the device on the intake closest to the air cleaner. Read this http://www.atlanticz.ca/zclub/techtips/EFI&fuel.htm. Also when you get back to us try to use better grammer and senteace structure. Quote Link to comment Share on other sites More sharing options...
Mr.INSANE Posted February 23, 2008 Share Posted February 23, 2008 woldson said: Dose this also happen when reving the engine under no load. My quick guess is the mass air flow sensor, the device on the intake closest to the air cleaner. Read this http://www.atlanticz.ca/zclub/techtips/EFI&fuel.htm. Also when you get back to us try to use better grammer and senteace structure. There is no mass airflow sensor on a 280Z, You probably mean AFM Quote Link to comment Share on other sites More sharing options...
woldson Posted February 24, 2008 Share Posted February 24, 2008 Yea sorry just could not think of it at the time. The bible was my clear all. Got sloppy. Quote Link to comment Share on other sites More sharing options...
