Brake booster vacuum help / running a supercharger
Get a vacuum canister from Jegs or Summit, then T it off that vacuum source, thats what I'm using.
It comes with a one way check valve.
I think his problem is that he doesn't have a vacuum source.
I would T off the PCV, if there is absolutly no where else that can be used, even drilled and tapped.
hydroboost.com
hydraulic assisted brakes like some trucks have, but I don't know if this would fit in a z car.
hook it up to a power steering pump, but if the engine shuts down, its like power brakes without the power assist. You really have to stand on the pedal to get it to stop.
