T56 Slave Question
Just got a tilton 7/8 clutch master and braided line. I'm trying to find a metal slave with a bleeder screw. I have found a resin master w/o bleeder but what a pain. Any suggestions would be appreciated. Mark
I too would like a metal bodied slave - the JTR method of tapping the resin makes me nervous. It sounded for awhile as if the T5 slave might be different or at least accept a standard hose fitting but I believe this has since been disproven. At least one person is using a stock Datsun slave but having had one of those die on me already I think I'd be nervous about that (sigh). My father owned a Z for years - he had "several" slaves leave him stranded. (ahem)
So, at this point I'm resigned to using the JTR method of tapping the resin body. several others here have done this and appear to be having NO problems. This being the case I suppose I'm just being silly worrying about it but I'd still be interested if you or anyone else has ideas for a metal slave!
What other RWD cars used the T56T5 with a hydraulic clutch? Viper, Vette (?), Camaro, anything else a possible donar?
Guys,
I really don't think you have anything to worry about with the slave offered by the factory. I have been using mine for over 900miles now, and it sits with in about 2 inches of my exhaust pipe. It works fine. The thing is wrapped in heat barrier to help with heat issues, but I drilled and tapped mine and ran a 1/8" to 3AN fitting into it and it is fine. The plastic is a space aged nylon designed for strength. AP Gurlock makes the unit and also makes a lot of other stuff out of the same matterial... For the space shuttle. It is strong, durable, and shouldn't leave you stranded. Buddy of mine that ownes a shop in Woodbridge swapped one out of a 95 camaro that had 135,000 miles on it and the thing was in good shape when he took it out. Trust me, they are good units.
Your only other choice is a hydraulic throwout bearing by tilton and a few others...
Mike
mjk
  • 1 month later...
quote:
Mike
Have you seen one of hydraulic throwout bearings installed? I've seen pictures of the part, but was curious how they anchor it on the bellhousing/throwout bearing sleeve?
Was just curious, they look like a compact little idea, but wondered how well they worked. confused.gif
Best regards,
Lone
