Turbo on a high comp. L28 engine
kvansic162
I plan on using the hi-6 ignition with the boost retard controller. I'm more worried about the cam profile being a problem. I've heard an agressive NA cam is not good with turbo's.
How many degrees of overlap? If it is around 112*-114*, you'll be fine.
ZGad:
Did you want overlap or LSA/Lobe Center?
Can't imagine a turbo cam with much more than 48 degrees of overlap...
Thanks Brad
:oops: ..I meant lobe center I think my old ISKY turbo cam was 44* overlap
I was about to EDIT it, but I am not able to for some reason...
