LS1 Autometer Tach problems
I hooked up the white 'tach' wire from the PCM to the Autometer. Tach was working fine with the L6. Cut both wires on the back of the tach to make it 4 cylinder. I get nothing - no needle movement at all. From LS1tech forum I tee'd a 480 ohm pull-up resistor (from 12v source ... actually tee'd into the tach power wire) into the signal wire and still nothing. No movement at all. I know it's getting power and ground as the gauge light comes on and the power & light wires are spliced together. Also verified there is continuity from the gauge green signal wire to the white PCM wire. Any suggestions or ways to diagnose?
Thanks
Cameron
on the back of my AM tach there are switches that you have toggle to be in the right position for a V8, 6cyl or 4cyl... i know that both have to be in the "up" position for V8 (4pulse), both down for a 4cyl (2 pulse) and first down, second up for a 6cyl. (3pulse)
Is yours set up properly?
Mine is old so there are no switched there are wires you cut. One is orange the other brown. You cut both for 4 cyl and mine are both cut so yes it's set-up right.
Thanks
Cameron
Anyone? Can't calibrate the G-tech ... or know when to shift ... until I fix this stupid thing. I'm hooked to the white wire ('02) and I get nothing. I realize it's a frequency but so should read average voltage (~9V from what I've read) but I get nothing. Anyone know if there is some type of fuse or something maybe I dont have hooked up that runs the Tach out ... kind of like the back-up light +12V that you have to feed the PCM?
Thanks
Cameron
