Guest znow white Posted March 15, 2008 Share Posted March 15, 2008 I just bought the msa harmonic balancer http://www.thezstore.com/page/TZS/PROD/PEM06/10-2139 anyone running these ? I got it because my old crank pulley was soaked in gas for too long and i was afraid of the glue damaged rubber that holds the two pieces this is for a turbo build. Im sure i can physically run this on the page it says from 70-83 byt nothing mentioned about turbo.. is it good or bad for a turbo motor . It says in description its degreed +20 what do they mean by that. Is it already +20 degrees of timing by adding this?! or just the way its marked. Thanks in advance Quote Link to comment Share on other sites More sharing options...
510six Posted March 16, 2008 Share Posted March 16, 2008 Model Restrictions: For L-Series engines only. Not for use with smog pumps, power steering, or air conditioning. If your not worried about, power steering, AC , should work fine.The timing marks allow for up to 20* of timing adjustment, you will have to manually check and verify TDC. Quote Link to comment Share on other sites More sharing options...
Mr.INSANE Posted March 16, 2008 Share Posted March 16, 2008 If you have a 240Z like your signature says you should be fine, This Harmonic balancer should be perfect for a turbo. Consider that most members use the stock OE balancer which is 20 plus years old I'm sure this is a lot better balanced than those are Quote Link to comment Share on other sites More sharing options...
zguy36 Posted March 16, 2008 Share Posted March 16, 2008 To use this pulley, you will have to use a belt from a 240 motor, not the 280 belt. This belt is a bunch narrower. Also, the pulley is about 15% smaller diameter, so you might even want to go with a tad shorter belt. A good parts store can look up the specs and get you one a bit shorter. As for the pulley, I haven't put any miles on it, as it was installed this winter. Come summer, I'll let ya know! Quote Link to comment Share on other sites More sharing options...
wigenOut-S30 Posted March 18, 2008 Share Posted March 18, 2008 I have this pulley installed on my L28ET using MS&S. I think I might be off by 5 deg or something. the 5 different timing marks make it hard to tell whats what.. So far I have revved it to 6500 and seems really smooth. Quote Link to comment Share on other sites More sharing options...
Guest znow white Posted March 20, 2008 Share Posted March 20, 2008 Thanks guys exactly what i was looking for Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted March 20, 2008 Share Posted March 20, 2008 Hey guys i was looking at getting this dampner also and i can see spending the 80 bucks on it but what i cant see is spending the 40 bucks for the bolt and washer. Is it really needed and if so why? Quote Link to comment Share on other sites More sharing options...
z-ya Posted March 21, 2008 Share Posted March 21, 2008 I have the same damper on my NA 10:1 L28. I run a ZX alternator on it, so I swapped the pulley from a 240Z alternator so that the thinner belt sat in the alternator pulley correctly. I also had to hone the damper so that it would fit the crankshaft without too much force. I also had to file the woodruff key slot to make it fit. I mounted a 36-1 trigger wheel on mine for EDIS, so I had the whole thing re-balanced at a balancing shop. The stock washer and bolt work fine, don't waste your money on the "special" one. Quote Link to comment Share on other sites More sharing options...
