new 1971 240z do I need a lead additive and do I adjust my valves regularly
Guest libbyde
Guest libbyde
Hi Everyone,
Sorry for the newb question but I just bought a 1971 240z all stock and I was wondering if I need to use a lead additive in my gas? Also do my valves need to be adjusted regularly? Any other special things I need to do?
Thanks,
Ron
If your valves are making noise then you can adjust them. You just need some shims, a 14mm wrench, and a 17mm wrench.(IIRC)
Doing the valves is about a 45 minute job and just follow the Haynes manual instructions or the FSM(Field Service Manual) if you have access to one.
OTM
The 240Z was designed for leaded fuel. Running unleaded will eventually cause damage to the valve seats, which can be fixed by installing new hardened seats. It's a slow process and in all likelihood your car has been running on unleaded for the last 20 years or more, so I wouldn't worry about it too much.
The valve adjust requires only the 14 and 17mm wrenches and a feeler gauge, don't go looking for shims because there aren't any. The factory service manual is sometimes available for download here: http://www.carfiche.com. A Haynes/Chilton type guide will also have all the info you need for the valve adjust in addition to all the other typical service procedures (setting point gap, etc).
