jeffer949 Posted April 13, 2008 Share Posted April 13, 2008 There is a maxima diesel in the jy by me and im going to go get the crank the first thing in the morning. I would pull the whole motor but i just dont have that much extra money right now. Id like to get the parts to the diesel guys but i cant put that much money up front. So is there anything that i should get?? besides the crank? that i could def. sell? Its a complete car and the whole motor is there. im thinking maybe the intake but idk. Well your input would be great. oh ya the crank will probably be for sale depending on how much i can get for it? might keep it in case i want to build a stroker someday. Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted April 13, 2008 Share Posted April 13, 2008 depending on what they want for the diesel fuel distribution pump, I would be interested in having a spare. I might also be interested in the injectors if they dont charge alot for those. If the pump is under $50 id be up for it. If the injectors are under $5 each Id be up for it. The injectors are actually bolted on the passenger side of the head, the pump is driven off the front pully and will end up getting pulled before you pull the crank. dont forget your 27mm to get the crank pulley off Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted April 13, 2008 Author Share Posted April 13, 2008 how hard is it to pull the crank with the engine still in the car?? Quote Link to comment Share on other sites More sharing options...
Challenger Posted April 13, 2008 Share Posted April 13, 2008 Not easy. Ive heard its a pain to change a oil pan gasket with the motor in the car, Im guessing pulling the crank would be pretty difficult. PM sent. Quote Link to comment Share on other sites More sharing options...
madmatt48 Posted April 13, 2008 Share Posted April 13, 2008 Not easy. Ive heard its a pain to change a oil pan gasket with the motor in the car, Im guessing pulling the crank would be pretty difficult. PM sent. Yes, pulling the oil pan for maintenance, not much clearance have done it twice with my S-130 1979 280zx. I have dissassembled a few engines to the block for parts or piston/rod inspection while they are still bolted to the engine mounts due to not having a cherry picker at the time. You could get to some of the crank removal points, but to pull the crank, you need to remove all your engine accessories, head, driveshaft, transmission, clutch, pressure plate, flywheel, crank pulley, timing front cover (did I miss anything) out of the way to gain access to all the crank removal points. Now if you get the car up on strong stable jackstands, support the engine's weight by placing a large block or another stable jack stand under the front of the transmission where it meets the engine, you could then remove the front crossmember and steering rack as an assembly and get enough access to remove the crank. In my opinion, with all the work I just described above just to get to the crank with the engine still in the car, removing the engine as an assembly and placing it on a work stand is the best way to go. Hope this helps. Quote Link to comment Share on other sites More sharing options...
cockerstar Posted April 13, 2008 Share Posted April 13, 2008 Personally, I'd just find out how much they want for the whole engine and if it isn't ridiculous get it. Then you can pull the crank where you're comfortable and then sell the parts off of it that you don't want. How much are they asking for the crank? I haven't actually been to a pick and pull myself, so, what condition would they expect you to leave the rest of the block in if you took the crank out there? What kind of condition is the whole car in? Quote Link to comment Share on other sites More sharing options...
naviathan Posted April 13, 2008 Share Posted April 13, 2008 Seriously, just get the entire engine. I wish I could come across one here in Eastern NC that's complete. I wanted to try a diesel Z with MegaSquirt to see what kind of fuel mileage I could get from it. Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted April 13, 2008 Share Posted April 13, 2008 Seriously, just get the entire engine. I wish I could come across one here in Eastern NC that's complete. I wanted to try a diesel Z with MegaSquirt to see what kind of fuel mileage I could get from it. The diesel injection system is completely mechanical, no need for a computer. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted April 14, 2008 Author Share Posted April 14, 2008 Well i didnt make it out there today. i think i might try and go get the whole motor this week since its so much work for just the crank. ill have to get it some how. Quote Link to comment Share on other sites More sharing options...
JSM Posted April 14, 2008 Share Posted April 14, 2008 Let me know if you need some help Jeff. Quote Link to comment Share on other sites More sharing options...
Daeron Posted April 14, 2008 Share Posted April 14, 2008 intake manifold might be a worthy investment too, if it isnt too expensive. Lucky.. I wish one of MY junkyards had a diesel maxima... but i don't feel like driving 250 miles to steal your find. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted April 16, 2008 Share Posted April 16, 2008 It is hard enough tearing an LD28 down on an engine stand... Also you are going to have to take the transmission out to unbolt the rear of the crankshaft from the flexplate/flywheel for removal. Might as well pull the motor. Quote Link to comment Share on other sites More sharing options...
terrycoxusa Posted April 17, 2008 Share Posted April 17, 2008 Anybody Have A Diesel Z Car? Quote Link to comment Share on other sites More sharing options...
