larsz Posted April 16, 2008 Share Posted April 16, 2008 I have the SDS unit EM6F fuel & spark with the L-28ET .This symptom only happens when the engine is hot & sits for a few minutes after running. It makes a loud backfire pop out the exhaust & won't start right away until it cools down a bit. It took almost 5 minutes before I could get the car to start again & a lot of backfiring in between like gun shots. After it starts up it runs fine. The plugs look okay. Any advice here? Thanks. Quote Link to comment Share on other sites More sharing options...
Nigel Posted April 16, 2008 Share Posted April 16, 2008 Is this something new, or has it always been doing this? Mine has a hard time with hot starts too, but it doesn't backfire. Quote Link to comment Share on other sites More sharing options...
Warren Posted April 16, 2008 Share Posted April 16, 2008 This may or may not apply to your circumstances, but from past experience, backfires from my engine have been caused by lean conditions. Noticing that the default programming values for Engine Temp show a value higher than 0 in the top 3 temperature ranges, and the sample maps provided with the system show an even higher value in those ranges, it might be a heat soak condition. Taking that into account and reading the latest SDS Manual, it states: Some engines like a little additional fuel when hot starting to compensate for hot fuel in the fuel rail due to heat soak back conditions. Extra fuel can be added until water circulation brings the engine temperature below this threshold. If you are doing this be sure to only enter numbers above the engine temps which are in the normal operating range. To check if this is a the problem with hot starting your engine, use the rich/lean knob to see if it's looking for or wanting more or less fuel at those high temperatures. Adjust the Engine Temp values accordingly. This is just a suggestion for troubleshooting the issue and may not provide you with a reasonable solution, but it's always worth a try. Warren Quote Link to comment Share on other sites More sharing options...
larsz Posted April 17, 2008 Author Share Posted April 17, 2008 Nigel said: Is this something new, or has it always been doing this? Mine has a hard time with hot starts too, but it doesn't backfire. Well when it had the stock electronics , it never did this. But when I put in the SDS unit it just did it all the time. I will try to change the values & maybe re-check the timing too. Quote Link to comment Share on other sites More sharing options...
larsz Posted April 17, 2008 Author Share Posted April 17, 2008 Warren said: This may or may not apply to your circumstances, but from past experience, backfires from my engine have been caused by lean conditions. Noticing that the default programming values for Engine Temp show a value higher than 0 in the top 3 temperature ranges, and the sample maps provided with the system show an even higher value in those ranges, it might be a heat soak condition. Taking that into account and reading the latest SDS Manual, it states: Some engines like a little additional fuel when hot starting to compensate for hot fuel in the fuel rail due to heat soak back conditions. Extra fuel can be added until water circulation brings the engine temperature below this threshold. If you are doing this be sure to only enter numbers above the engine temps which are in the normal operating range. To check if this is a the problem with hot starting your engine, use the rich/lean knob to see if it's looking for or wanting more or less fuel at those high temperatures. Adjust the Engine Temp values accordingly. This is just a suggestion for troubleshooting the issue and may not provide you with a reasonable solution, but it's always worth a try. Warren Alright Warren, I will try to do what you are suggesting. I also called SDS & they said it might be also a problem with the ECU . I have to call them with the serial number. They apparantly have an update for the unit. The tech also thought it could be the coil packs but they seem to check out okay. Thanks for your assistance. Quote Link to comment Share on other sites More sharing options...
larsz Posted July 31, 2008 Author Share Posted July 31, 2008 larsz said: I have the SDS unit EM6F fuel & spark with the L-28ET .This symptom only happens when the engine is hot & sits for a few minutes after running. It makes a loud backfire pop out the exhaust & won't start right away until it cools down a bit. It took almost 5 minutes before I could get the car to start again & a lot of backfiring in between like gun shots. After it starts up it runs fine. The plugs look okay. Any advice here? Thanks. After talking with the SDS rep. It was pin pointed to the sync magnet not seen when the motor was hot. I had to re-align the hall sensor so that it would fire up. Walla , it starts now all the time! Quote Link to comment Share on other sites More sharing options...
Warren Posted July 31, 2008 Share Posted July 31, 2008 Thanks for the update and followup. Quote Link to comment Share on other sites More sharing options...
drzed Posted August 1, 2008 Share Posted August 1, 2008 Nice to see an update on a problem like this - really helps when others have a similar issue. Thanks Quote Link to comment Share on other sites More sharing options...
