PetesPonies Posted April 26, 2008 Share Posted April 26, 2008 where does the negative battery cable connect ?? And where is the engine to chassis ground strap mounted? And lastly, what length cables ( + & - )are considered correct length? I'm looking for stock location points. Thanks Quote Link to comment Share on other sites More sharing options...
PetesPonies Posted April 26, 2008 Author Share Posted April 26, 2008 bump Quote Link to comment Share on other sites More sharing options...
supertip Posted April 26, 2008 Share Posted April 26, 2008 Negative battery cable connects to the negative battery post. Quote Link to comment Share on other sites More sharing options...
PetesPonies Posted April 27, 2008 Author Share Posted April 27, 2008 what a genius answer and a waste of bandwidth. Quote Link to comment Share on other sites More sharing options...
supertip Posted April 27, 2008 Share Posted April 27, 2008 lol, im sure somebody saw some humor in it, but seriously, tomorrow I will take a picture of the stock location, unless someone can help you before. Quote Link to comment Share on other sites More sharing options...
PetesPonies Posted April 27, 2008 Author Share Posted April 27, 2008 I would appreciate that. Quote Link to comment Share on other sites More sharing options...
PetesPonies Posted April 27, 2008 Author Share Posted April 27, 2008 I found this pic on this site which does a good job of showing cable location. What it doesn't show is ground strap location though. Quote Link to comment Share on other sites More sharing options...
PetesPonies Posted April 28, 2008 Author Share Posted April 28, 2008 anyone with ground starp info? where? Type of strap? Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted April 28, 2008 Share Posted April 28, 2008 The large negative battery cable connects to the top starter bolt the smaller one bolts the firewall: See top bolt in firewall. Quote Link to comment Share on other sites More sharing options...
garvice Posted April 28, 2008 Share Posted April 28, 2008 lol, im sure somebody saw some humor in it I was thinking the same smart a$$ response. Cracked up when I read it. Quote Link to comment Share on other sites More sharing options...
PetesPonies Posted April 28, 2008 Author Share Posted April 28, 2008 so is the pic accurate enough such that both cables are black in color as opposed to a red and black? Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted April 28, 2008 Share Posted April 28, 2008 so is the pic accurate enough such that both cables are black in color as opposed to a red and black? As far as I know both cables were black 1972 240Z 4K original miles 1973 240Z 8K original miles If you want to be sure check out http://www.classiczcars.com as they would know better. This is all the proof I had time to find. Good Luck!! Quote Link to comment Share on other sites More sharing options...
PetesPonies Posted May 2, 2008 Author Share Posted May 2, 2008 OK, so the only ground strap to the body is the piggy back line off the negative cable right? Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted May 6, 2008 Share Posted May 6, 2008 Yes Quote Link to comment Share on other sites More sharing options...
skib Posted May 11, 2008 Share Posted May 11, 2008 i have had mine bolted to the top starter bolt and to the trans bolt right by it and had no problems with eather Quote Link to comment Share on other sites More sharing options...
