V8INtheZ Posted April 30, 2008 Share Posted April 30, 2008 Hey guys. My friend was just given a decent 240z. Appears mostly stock including a stock looking driver door sil plate. It looks factory, but it lists his GVRW as 2400 pounds Front is a tad under 1200, and rear is a tad over 1800 for a total of 2400 even. This cant be correct, what do some of your guys plates read? It has the matching consecutive unit number as listed on the dash plate, and the engine compartment plate...Im confused? Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted April 30, 2008 Share Posted April 30, 2008 that plate shows the maximum vehicle loads. meaning, the maximum you can load onto that car safely. say the car has a CURB weight of 2000lbs, and a maximum cargo load of 400lbs, that brings the gvwr to 2400lbs. Quote Link to comment Share on other sites More sharing options...
V8INtheZ Posted May 1, 2008 Author Share Posted May 1, 2008 Well, thats my whole point. I understand what the GVRW is, thats why it cant be 2400 pounds. That would mean the Z has a curb weight of like 1900 pounds...Thats way too light. Im trying to figure out where the plate came from, or if maybe its just a mistake from the factory. Quote Link to comment Share on other sites More sharing options...
V8INtheZ Posted May 5, 2008 Author Share Posted May 5, 2008 Nobody else has any input? Quote Link to comment Share on other sites More sharing options...
DuoWing Posted May 5, 2008 Share Posted May 5, 2008 I've actually seen this on another Z. I believe it was a 71' a guy here in Ohio has a 240 he restored and the sill plate shows GVWR 2400. I couldn't believe that. Like you said that would indicate a ridiculously low weight. I almost wouldn't be surprised if they started calculating it differently a year or so later. The 73' I looked at had a weight of around 2700 or 2800 lbs. I always try to figure these weights out by assuming 2 people at 150lbs each, so about 300 lbs, maybe 50 lbs for cargo, 20-30 for spare tire, and at least 50lbs for gas. Although I have no idea how they determine, but I see what you're saying as this would indicate a curb weight of less than 2000 lbs. Quote Link to comment Share on other sites More sharing options...
johnc Posted May 6, 2008 Share Posted May 6, 2008 Although I can't verify this, I was told by a knowledgeable person that the early series 1 USA cars had an incorrect GVWR and that's one way to tell if its an early car or not. Quote Link to comment Share on other sites More sharing options...
Daeron Posted May 6, 2008 Share Posted May 6, 2008 fascinating.. I'll have to see if my dad saved the plates from his 70.. Quote Link to comment Share on other sites More sharing options...
V8INtheZ Posted May 6, 2008 Author Share Posted May 6, 2008 Hmm, must be some sort of mistake. Thanks for your guys input. We will just have to weigh the car to be sure Quote Link to comment Share on other sites More sharing options...
