R&p Swap
Guest hekatombe
Guest hekatombe
Hi,
I want to swap the 3.96 R&P of my r200 shortnose (with ABS sensor) for a new set of 4.36 R&P.
Do you know where can I find an explanation of how to do it?
I want to do it myself with the help of my friend (he is mechanic)
Many thanks
If you have to ask, it's probably going to turn out bad. I've done quite a few and I think it's easier rebuilding an engine or trans than setting up a diff. You need a press, bearing seperater, dial indicator, calipers or mic, and an assortment of shims to adjust the pinion height and backlash. Then you have to get the pattern right and with out experience that can take some time to get right. I would guess 95% of professional mechanics haven't set up a diff.
I would either buy a 4.36 diff or bring it to a drivetrain shop that does alot of diffs.
