Crank angle sensor not connected (280zx)
G'day, just been pulling out my a/c system our of my 280zx and noticed that the crank angle sensor is not even plugged in. I don't know a whole lot about it but from what i understand it's for ignition timing etc and the car shouldn't even run without it. Yet the car runs perfectly fine.
I am running a Wolf 2D ecu, would this have anything to do with its disconnection?
Also, While i'm in the electrical thread; my cruise control doesn't work (i'm tempted to pull the whole thing) and the whole system looks really quite complicated hence i assume not an easy fix, or, is there something i can check which its often the fault?
thanks.
Dave.
I don't knwo about australia but state side the only models taht came with an external CAS was the 81 turbo, all other turbo's had the cas internal tot he distributor and all n/a's used a VR sensor in the distributor with no cas
